RPL- 4/5A (Mobile ground landing radar system) (Saját)
3D modellből papírmakett tervezése
Papermodels under development - Papermodels made from 3D
HozzászólásSzerző: atlon » 2014.03.14. 11:30
Sziasztok, ezennel bemutatom a tervezés alatt álló makettemet - RPL- 4/5A (Mobile ground landing radar system)
Mobile radar airport complete RPL-4A "Mosquito" belongs to the means of radio and aviation security in the so-called Radiolocation landing system.
name "mosquito" earned thanks to a set of lattice structure supports, reminiscent of the creature. Nevertheless, it was a mobile device, used to deployed at all airports constant (not only our Air Force, but also other air forces of the former Warsaw Pact). For its high mobility had been used to security of aviation activity on the backup airports. (Rather, it is used more, the so-called backup set) The set was located and transported 3 148 Tatra vehicles with trailers:
 first TATRA 148 truck: aerial unit of airport surveillance radar RL-4A (the designation "B" ), trailer A10V (later PV 2418): Institutional Unit airport surveillance radar RL-4A (container - the designation "A" ) and EC 30 kW generator ( designation "G" ).
 second TATRA 148 truck: aerial unit landing radar RP-4A (the designation. 'E' ), trailer A10V (later PV 2418): instrument landing radar unit RP-4A (container marked "D" ) and EC 30 kW generator (labeled "G" ).
 3rd TATRA 148 truck: spare sand load, used to "anchor" a set of connecting cables, trailer A10V (later PV2418) machine unit control center RPR-4A (container designation "F" ) and EC 30 kW generator (labeled "G" ) .
At many airports to see aerial unit perched on a stable base (concrete rings) - excluding freight cars.
OR
Based on experience with airport radar RPL-4 resulted from its modernized version amended and new kit: RPL-5 . Main "visible" change in the surveillance (primary) radar was also accompanied by a secondary radar Russian production Koreň . A new set of RPL-5 is the addition of surveillance (primary) radar secondary radar ("root") with digital signal processing and its complement rdst R-832M . (Activity RL and RP and parameters are as RPL-4A ). Composition airport radar system RPL-5:
 Review (primary) radar RL-5 * Tatra 148VNM with transport frame: - Antenna unit AJ / RL ("B") * trailer PV 2418 with a transport frame and pallet: - Instrument Unit PJ / RL ("A") - The electric bus-30-3-400L ("G")
 Secondary radar SRL-5/RS-5 * Tatra 148VNM with recycl . frame, 2 pom. frames and crane - Antenna SRL (dual band, dual power supply) - Antenna transponder control - Instrument Unit PJ / SRL ("C")  The landing radar RP-5 * Tatra 148VNM with transport frame: - Antenna unit AJ / RP ("E ") * trailer PV 2418 with a transport frame: - Instrument Unit PJ / RP ("D") - The electric bus-30-3-400L ("G")
 Managing Workplace RPR-5 * trailer PV 2418 with a transport frame and pallets : - Managing Workplace PJ / RPR ("F") - The electric bus-30-3-400L ("G")
 Equipment SRL in isothermal container, other parts of the circuits for digital processing and displaying it in managing workplace. Antenna unit SRL is the antenna unit RL. Another change is the installation of cabinets rdst R-832M with resources on the rear end wall of instrument units RL, RP and RPR.
A Tatra 148 VNM - t nem fogom tervezni, mert azt már kiadta a Ripper Works ;)
Bocsi a magyar írásomat, de az nem megy anyira [blush]
Kép Kép Kép Kép Kép Kép Kép Kép Kép Kép Kép Kép Kép
atlon
Csatlakozott: 2010.06.19. 09:50
Re: RPL- 4/5A (Mobile ground landing radar system) (Saját)
HozzászólásSzerző: Gaccso » 2014.03.14. 20:30
Idáig semmi gond nem volt a magyaroddal. Érdekes projektbe kezdtél. Egy képet tehetnél fel, végül is ez a radarállomás hogy is néz ki eredetiben.
HozzászólásSzerző: atlon » 2014.03.14. 20:41
jaj bocsánat , elfelejtettem a fotókat :)
Hát akkor tessék ;)
atlon
HozzászólásSzerző: Gaccso » 2014.03.15. 19:54
Kíváncsi leszek, az antenna hálózott részét hogy oldod meg.
HozzászólásSzerző: atlon » 2014.03.16. 09:20
no potossan azt a részt még nemtudom hogyan csinálom meg :S bármilyen ötletetet elfogadok [thumbup]
atlon
HozzászólásSzerző: atlon » 2014.03.16. 09:38
egy kiss progresz - antenna tartó
atlon
HozzászólásSzerző: atlon » 2014.03.19. 15:20
egy kiss progresz
egy pár dolgot át kel rajzolny, és tip top lesz :)
atlon
HozzászólásSzerző: János » 2014.03.20. 12:23
Jól haladsz! Mi a méretarány?
HozzászólásSzerző: atlon » 2014.03.20. 12:40
koszi, 1:25 [thumbup]
atlon
HozzászólásSzerző: atlon » 2015.08.09. 20:54
egész projektet áttervezem [rolleyes] végre elkeztem használny a Rhin-ót [thumbup]
atlon
HozzászólásSzerző: János » 2015.08.11. 20:13
Gaccso írta:Kíváncsi leszek, az antenna hálózott részét hogy oldod meg.
A sűrű hálót nem lehet papírból megvalósítani, csak a vázat ami a hálót tartja. Ha én építeném meg, akkor biztosan a sokszor használt rovarhálót venném elő, és azt tenném rá a vázra.
Azt még megkérdezném mit is jelent az "AK Laser Cuts" cégjelzés?
HozzászólásSzerző: atlon » 2015.08.11. 20:36
helo , a hálót vagy lézerel próbalom kivágni, vagy azt a rovarhálót fogom hozzá elószedni :)
És a AK Laser Cuts cég? hát az ez : http://papermodelers.sk/viewtopic.php?f=131&t=6227#p141289 [thumbup]
atlon
HozzászólásSzerző: Bogyi » 2015.10.21. 11:12
Eddig jól haladsz. Gondolom a Rhino-n kívül még a Pepakuróat is használod ugye?
Nálam is így megy, rajzolás majd próba és átrajzolás. :-)
Vissza: Tervezés alatt álló makettek
